Kicker or Audiobahn
dbolemiss
Woundering which amp to put on which setup?
I have a kicker 600 pushing 2 infinity kappa 10s and i have 1 10" eclipse (older) 4ohm coming in a sealed box.I just picked up an Audiobahn A18001DQ.
So should i leave the kicker on the infinity or put the Audiobahn on them? and then put the kicker on the eclipse?
audiobahn has gone to crap. i had one of their latest releases last year. i think a 600 or 800wt amp and it would overheat and shut off often. keep in mind gains and everything was set correctly. and alot of shops around houston refuse to sell audiobahn amps
Ahh, okay, just making sure.
Honestly, I wouldn't use the Audiobahn on anything but if you have it and want to use it, throw it on the Kappas first, keep whichever sounds better on those and use the other for the Eclipse.
i go the 2 kappa in my Titan truck.
Going to put the eclipse in the armada.
Just woundering which amp i should put with which subs?The kicker is pushing the kappa very nice.
The eclipse sub is around 200w rms
the infinitys are 350w rms a peice.
The armada is my wife's car and i'm just trying to give it a little more full sound.
What is the Audiobahn amp Specs...?
I Think its Got a little too much power for Eclipse Sub...//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it has:
600 watts RMS x 1 at 4 ohms
1,200 watts RMS x 1 at 2 ohms
1,800 watts RMS x 1 at 1 ohm
1-ohm stable
Class D design
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
50-150 Hz low-pass crossover, 18 dB/octave
variable 0-18 dB bass boost centered 40 Hz
variable (15-40 Hz) subsonic filter
0-180 degree phase control
preamp outputs
dual cooling fans
cobalt blue illumination
digital voltmeter
remote bass control
17-13/16"W x 2-1/2"H x 12"D
this is the whole point of this thread,i want to match the right amp with the best sub set up.
I'm never going to turn either one all the way up,just want a better sound.
dbolemiss
dbolemiss
New Iberia,LA
dbolemiss
