Kicker L7's!!
Originally posted by mrray13 opinions on this? i go talk to him tomorrow or saturday. i think i will if it's free!//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif if i do, i give a comparo review on the HX2 vs L7, even though the L7's will have an early size advantage. whatcha think?
Sounds cool. But the only comparison would be the SQ side of things. The L7's should destroy the HX2's in SPL. If for no other reason just shear cone area difference. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Something that put's out around 1200w would be ideal. Which amp depends on which version of the subs. I think they still come in Dual 4's or 2's don't they ? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well it seems like the power HX2's and the L7's seemed to be priced right around the same range, but from what I remember the HX2's can take a few more watts (but I may be wrong, have to check it) but I think the Rockford is a preety sick sub also I was very impressed with the 2 installs I have seen them in in competitions this year
Originally posted by denim well it seems like the power HX2's and the L7's seemed to be priced right around the same range, but from what I remember the HX2's can take a few more watts (but I may be wrong, have to check it) but I think the Rockford is a preety sick sub also I was very impressed with the 2 installs I have seen them in in competitions this year
Don't get me wrong I am a long time Fosgate fanatic //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif But if you put both setups on the meter. I believe the L7's would tear em' up //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Now if we are talking SQ wise I would pick the Hx2's. But SPL wise I think the L7's will take em'. I could be wrong. But I think they would //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
unfortunately. i have the punch hx2"s( they are 8's). they're rated 400wrms, 800 peak. the 10" L7's (which would go in, should i decide to do this)are 600 and 1200 respectabley. i just saw that they have 8" L7's. they r rated 450 and 900. the 8's would drop right in. the 10's need about 2" more mounting depth, which i don't have! that be a closer comparo anyway.
some #...........
  • 8" HX2 8"L7
  • Fs 40 38.5
  • Sens. 83 84.9
  • Qts .5 .52
  • Vas(cuft) .318 .55
  • Xmax 14mm 10.7mm
i can't remember how to figure the surface area of a circle, but the L7's have a displacement of 59.5 ^in. anyone care to refresh my memory on the math for the circle?
what y'all think about that comparo?
So if i were to get a pait 12 L7's what would be an ideal amp for me to buy..possibly a cadence???andplease more suggestions.
as to other 12's.......power or punch hx2's, jlw6's, eclipse Ti's or alums, shiva's
as to the amp......jl 1000/1, jbl 1200/1, rf power 1500.1 or the punch version,
kicker xs?1000, mtx 81000D
area of a circle - pi x R^2 my man //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Yeah the 8's would be a closer comparison. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by mrray13 thnx ramos:D i don't know if it would be worth it really,they sure are close. i might still though:confused:
IMHO I don't think you really would tell much, if any difference at all. But on the other hand it would be interesting to actually see if you could hear any difference. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
813
gdatw019
gdatw019
fayetteville, nc
ramos
    Jun 1, 2024
    May 31, 2024
