ampresearch
Hey guys
Several month ago i started to hear a very annoying "slapping sound " coming from one of my L7 15 in subs. i took it out and inspected it only to find no noticeable problem.
I thought for sure it was blown but everything looked perfect. I started to search the net and found that a lot of people had this same problem. Many of them noted that the glue that holds the edge of the rubber surround to the basket had come loose allowing the surround to lift up a tiny bit during high levels and of course coming back down causing a slapping sound. I pulled the sub again and sure enough i was able to lift the surround with my finger clear off the basket
Due to the design of the L7 this was not something you could have fixed. I tried to stick some glue around the edges to hold it down and although it did work quite well i could still here the noise a tiny bit. I called kicker and asked about it and they did say it can happen but they could not repair it. I started to look into getting a new pair but before i did i thought i would try and fix it myself. If it works great. If not i was buying new one anyhow. Nothing to loose. This is a picture log of what i did.
First i examined the black retaining ring that goes around the top of the sub. One thing is for sure. It is on TIGHT and not meant to come off.
Time to try and pry it off i gave it a few smacks with a rubber hammer. My idea was the same used for breaking threads loose on a big bolt. A sharp smack send a shock wave that break free rust glue or just about anything you want to break free. This worked great and i was able to get my chisel under the lip
From there i simply continued all the way around the basket until the retaining ring was free.
After removing the top ring i was able to pull the surround away from the basket with little to no effort the glue had almost completely failed.
