Kicker L7 Need Advice ASAP
What's up everyone.
I'm in a bit of a dilemma so I wanted to get it out there.
I currently own two 12" Solo Baric L7's (2ohm) and 1 zx750.1 amp. I do not have a box. I am in the market for a box. My dilemma is whether to just get a single box (found one on ebay, ported tuned at 32hz). Or should I get a dual box for my two subs.
Basically, would it be better to run one L7 with the zx750.1 or two L7 on the zx750.1? Which would put out more db in a good, ported box. Eventually I'm looking to get a zx1500.1, but gotta save up. Just need some bump for now.
Thanks for looking
I have 4 12"L7s @ 4ohms, each with a zx750. I would get a zx1500 for the pair and put them in a ported Probox. Those are tuned at 50, I think. That should get you some bump.
the kicker outputs more then the jl. if you had to go with either stick with the kicker, i had that amp its beastly. i mean i know you dont wanna have to buy a box now and another later. if you absolutely have to have bump asap then get a single ported and use the kicker. if you can wait take his advice and get an amp that does at least 1500 at 2ohms liek the zx1500.
skohon
skohon
McHenry, IL Collinsville, IL
skylineTT
