Kicker L7, elemental Type A, Magnum D2, adire brahmas
footballfreak16
10
Va
hey
Im a highschool student and alot of my friends have pretty descent systems. I want to Kick their BUTT with my new system. Which of these will help me beet my friends?
-12" magnum D2
-12"Kicker L7
-12"elemental type A
-12" Adire Brahma
Thanx alot!
and what yuo mean by "beat". You want louder and or better sounding? The l7 will most likely make it sound wrose...don't try to "beat" them with a brahma cuz you'll probly break it (by turning it up too much). Unless you get two 12 A's I doubt you will beat them by much. D2 would probly be your best bet. get a couple D2's and port them. Or order a 15" d2.
Just because you're Brahma broke doesn't mean it can't handle high volumes. I've seen 3 or 4 installs with Brahma's, and they sounded pretty good to me, and got fairly loud with more than what your Tsunami 1100 puts out. Perhaps you did a poor job installing it or purchased a faulty model....
many people on this forum have had horror stories with brahmas so hes not the only one.
I would go with a 12" XXX. This sub will amaze everyone
738
footballfreak16
footballfreak16
Va
ineedbass
    May 24, 2024
