Kicker KX850.2 Decent condition.
silvercookie
WRX
7,703
Queens, NY
Kicker KX 850.2
Works 100%. Can't remember if the red LED bar under the kicker logo works and im about 99% sure the fan works.
Previous owner did a fairly crappy paintjob.
There are scratches on the amp/endcaps.
A couple of the mounting fleet plastic cap things are broken/gone.
Previous owner cut gaps in the endcaps as seen in the pictures. I would assume to run wires through.
There are also no screws to screw down the endcaps or on the amp as seen in the pictures.
Ran it @ 4 ohm bridged on a pair of e8v2's gain way less than half. Amazing amp.
$200 shipped.
[/url]
It should do fine man. Id recommend this setup for the money.I have two of these amplifiers and they are great for the $coin. The Hawk 15s Slamm...
539
silvercookie
WRX
silvercookie
Queens, NY
michaellane
    May 12, 2024
Brendon Jenness
    May 11, 2024
