Sold Kicker KX650.4
matew1
Kicker KX650.4
This amp is in flawless working condition, with the standard visual smudges. I lost the screws to the end caps in my pocket when I uninstalled it, but they may turn up. If they do I will update the post. I still have the original box.
Specs:
* 4-channel car amplifier
* 120 watts RMS x 4 at 4 ohms (170 watts RMS x 4 at 2 ohms)
* 325 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
* cooling fan
* 2-, 3-, or 4-channel output
* CEA-2006 compliant
* Tri-way capable (Tri-Way crossover required)
* speaker- and preamp-level inputs
* variable front and rear high-/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
* variable bass boost (0-18 dB) centered at 40 Hz with wired remote control
* three-way protection circuitry
* requires 4-gauge power and ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
* 22-1/2"W x 2-9/16"H x 9-15/16"D
Looking for $150 + shipping (include your zipcode and I will calculate the shipping)
Also willing to trade for a similarly spec'd 4 channel amp that is no longer than 15" in the widest dimension.
matew1
matew1
santa cruz
stereohead69
