Kicker kx650.4 help
Ampegamp
I am running a Kicker KX650.4 amp. Its 4/3/2 channel and I am running it as 2 channel. I have one sub running to the amp1 channel and one sub running to the amp2 channel. I am using the high level signal inputs with the rca dummy plugs in the amp 2 input (per the instruction manual). I am using both sets of high level inputs (1 for amp1 and 1 for amp2). The subs I am using are 12" kicker L5's dual 4ohm coils. When I turn the system on, there is almost No sound coming from the subwoofers. The indicator lights are green, so there shouldnt be a problem. What could the problem be. I wired the coils like the instructions said (series).
There is almost no sound coming from the sub. Bad ground maybe?
Two things come to mind-
Are the woofers moving a lot but there is not much bass? Try removing the amp 2 input plug and the RCA dummy plugs. If the bass works better there is a phase problem between amp 1 and amp 2.
Depending on the head unit it may be necessary to add a ground reference to the inputs of the amp. While it is playing try using a piece of wire to jump between the big power ground connection on the other end of the amp to the RCA shields on the signal end.
Ampegamp
Ampegamp
St. Louis
Polecat
michigan born
    May 14, 2026
michigan born
    May 14, 2026
