Kicker KX1200.1 ?
EPanther99
alright i got a new car so i sold one L7 and im having a custom slotted port box built for my remaining L7 and im thinking about selling my current amps and getting the kicker 1200.1 to power it, the 15 is dual 2ohm so i would be running at 1ohm mono to the amp....i was just wondering if anyone has used this amp and had any bad/good comments about it. ??
the cheapest i have found so far is $405 plus $20 shipping and that included the 1/0 ANL style inline fuse holder and 150 amp fuse which is like $50 worth of extras.
Well.....I don't think its worth that much.....there are plenty of good/better amps that put out the same power for less....check out the 1000+ Watt Amplifiers thread....
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Check Sig...Couldn't be more pleased with Kicker...//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
it soudns a good deal for me, cuz u prob gettin ANL fuse holder n fuse n all the stuff u need included in the $420.
not bad i would think. n they underrated.
The KX1200.1 is a very potent amp. I would reccomend it. They are solid, reliable, and are considerably underrated as has already been stated. The KX1200.1 or the JL 1000/1 will be my next amp, for sure. The KX has a subsonic filter. That is another plus.
I am running a KX1200.1 to my Brahma 15". Gains are at about half and the thing pounds pretty **** hard when i have my volume at like 12-14 (Alpine CDA-7894). Subsonic filter (as was already mentioned), stackable, lots of protections circuit stuff so the amp is not likely to blow, just likely to shut down till you fix the problem. Where were you looking to pick one up for 400? Got mine for about 80 bucks more than that. I am happy, though if I were doing it again, I would definitely look at the elemental nine.1, all depending on if you need the extra 450 watts or so.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
897
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
EPanther99
EPanther99
Elizabethtown KY
denim
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
