Kicker KX1200.1 KX-Series amp
yungmoney3000
hey guys i'm buying two Kicker 04S15L72 15" L7 Solo-Baric subwoofers and getting the Kicker KX1200.1 KX-Series amp along with them. I was wondering if anyone could tell me if this is a good setup or should I get two Kicker KX1200.1 KX-Series amps, one for each sub. Also can you give any reviews or suggestions you know about the subs and amp. If you can help out I would really appreciate it. //content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif//content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif
Thanks,
Dre
yungmoney3000, those subs will pound with that power!!! Just make sure you get a pair of KX1200.1's if you get the Dual 2-ohm model so the amps can be strapped.
Otherwise, you need Dual 4-ohm subs for a 1-ohm load on a single KX1200.1 amp. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
being that it puts out 1400+ rms on avg the amp does draw a considerable amount of current- although NO MORE than any other class D putting out the same amount of power
My experience with Kicker has been great-their ZR's were awesome, and my KX600.1 was solid and very underated as well. Highly recommend the 1200.1.
yungmoney3000
yungmoney3000
Raleigh, NC
denim
