Kicker CVR's burning smell?
it is usually customary to keep the gains low... ure prolly slowly popping ure voice coils (not from overpowering most likley, but from simply having gains to high) turn them gains down or else u will soon be able to cook weenies over your CVR voice coils
I would be careful. I also had 2 12" Kicker Comp VR's as one of my first systems and I ended up frying them. I smelled the same thing that you are smelling and thought it was the "new glue smell" or whatever people say it is. I would strongly suggest turning the gain down and not overpowering them. Also it may not be as loud as you would like with the gain turned down even more than it is now, but at least you will still have two functioning subwoofers. Funny smell = bad
make sure you have the wiring on the sub right,
Parallel: red to red-dot to (+)box,
black to black-dot to (-)box
Series: black to red-dot,
red to (+)box and black-dot to (-)box
Well, I figured it out....its 100% the new amp making the smell. Subs are fine. Just went ahead and played it for a good while today and eventually its not bad anymore. Must be b/c it is new...I am certainly not pushing the amp hard cause its barely warm to the touch after 2hrs of playing. This new amp is bigger in size than the old one, and im thinking the audio shop plugged the screw holes with some glue(that new amp sits over...cooling system flows over that area) that might be getting warm or the amp fan is pushing air by it causin the smell...another possiblity.
hope u dont mind if i ask a question in ur thread, dont feel like startin a new one
i have 2 cvr 15's..if im given em bout 400 rms (rated at 500) can i have the gain bout 3/4 up?
-DarkMatter-
-DarkMatter-
Newport News, VA
Jameseypoo
Mike Mccabe
