kicker comp vs alpine type-s in SQ
Depends on what your idea of "better" is. The Comp VR gets decent loud and sounds decent. The Type-S doesn't get quite as loud but sounds pretty good.
install depandant, and userdefination of SQ which would sound better...to some,more bump in a system sound better, to some, a flat line sounds good...so....
no the new type s's are great. I just installed them in a friends cars saturday nite. He love them, BUt the SQ of it is good, and they run $150 retail.
personally, i wouldn't get either one.....
i'd get the memphis power reference....gets louder then the comps (vr or otherwise) and sounds better (totally subjective)....better warranty then both.
but if i had to choose between those two..i'd get the comp vr...then the type-s..then the comp.
check into the pr's..u can get a pair for $150 (depending on size)....best mainstream budget sub on the market!IMO
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
i have the PR subs, but i would rather have the Type R's , but of corse i love SPL. BUt i do not have the PR in a sq type set up. THey do not need as much power as the Type R's tho.
the pr's are indeed extremely efficient..i have mine off 70wrms and most ppl think there is quite a bit more in my truck.
again, for the money, u can't beat the pr line of subs..IMHO
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
411
920
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
cowboyjmt
cowboyjmt
imperial,pa
mrray13
    Apr 28, 2024
    Apr 28, 2024
