Kicker Comp VR 12'S - bang for the buck?
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 857
    Participant list
U
Unregistered
Guest
Im planning on buying the Kicker Comp VR 12'S DVC. What box should i use (im going for more of the SPL side) and how many Cubic feet per sub? Im matching it with my Legacy LA790 1000x2 amp. Also, are these subs good for some bone rattling thump?i havent heard them thump before. Im just buying them because the watt ratings are to my likes.
12'' comp vr are good .--use a sealed box with 1.25 cu ft per sub
or
a ported box 2.0 cu ft plus port-- per sub
log on to kicker web site for box building spec
if you plan on building your own sub box
the legacy 1000.2 not so good check out these
crossfire 1000d,directed 1100d,( better built amps)
609
Guest
    May 16, 2024
    May 16, 2024
