Kicker Birthsheets
Scorpion
One quick question on two amps.
I am looking at the KX600.1 and the KX400.1 to power my 2 10" CVR's. What are the birthsheets numbers for these two amps??
The subs RMS is 300. They are 2 ohm Dual VC. So when I wire them up they will be either 1 or 4 ohm, correct??
Since they are both dual 2 ohm, you can get a 1 or 4 ohm resistence on each sub. This will allow you to wire them to .5, 2, 8, and I'm too lazy to figure out the last resistence, but it would be between 2 and 4 ohms....so get an amp that does the power you need at 2 ohms
Only a KX400.1 for the CVR's??? I Don't know about that, I am getting a pair of 10's for a buddy and plan on using the DX700. I think it is the cheapest most efective amp for the subs out there but I could be wrong...
Jon
who makes the DX700? nevermind i found it Kicker. will it be enough to power 2 12" CVR's? and while were on the subject, is this amp any good? Lanzar VIBE258:
2 x 400 Watts RMS at 4 Ohms
2 x 800 Watts Max at 4 Ohms
1 x 1600 Watts Max at 4 Ohms Bridged
2 x 650 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H x 17"L
thanks.
Bass Boost Circuit
Tri-Mode Capable
Gold RCA Inputs
Soft Turn On/Off
S/N ratio: 90dB
thanks.
You can find kicker dx700s on ebay for around 175 shipped. That lanzar amp you speak of is not of high quality. I have had expierence with them and i will tell you this, they clip easily and get warm when bridged. Spend your money right the first time and get the kicker dx700 or the kx600.
BUY Kicker //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I meant close 'by' Kicker....both Oklahoma boys.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
but you are right too...BUY Kicker... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Scorpion
Scorpion
Goodland, KS
Polecat
NorthFramingham
    Jun 30, 2026
