I just got the 08ZX750.1 and I have read that the remote bass boost is exactly like setting the gain, and I have also read that it is not. Can anyone clear this up? I know bass boosts are bad and that I shouldn't be using them, just wanted to make sure.
Also do I want the input level at high or low?
I want to get the lowest frequencies possible out of my subs. (2 12" cvr's) I was thinking since the cutoff freq. is 50 hz, I could turn up the bass boost (centered at 40 hz) up to the max of 18 db. I am thinking when I set my gain the first time, I will have this set to 18 db. I don't want it to cause distortion though.
My subsonic filter is 24 db at 25 hz. Is that good/bad and if possible should I change it?
Does the bass setting on my headunit affect my door speakers or does it also affect my subs? Should I keep the "subwoofer" setting at the lowest possible on my HU?
One last thing, does the gauge of the wire running from the amp to the subs matter?
Thanks, just wanted to clarify these things before I went in and damaged something.
