Kicker amps at 2 ohms?
gl-john
I have a kicker zx850.4 amp. I was running 4 6x9 at 4 ohms each. It worked fine but the speakers could not handle the power. I currently have two 6x9s in th front doors at 4ohms each and I just installed a kicker solobaric 12in square sub in a sealed box in the trunk. The sub is a 4 ohm sub. If I wire the sub to two ohms the amp will go into short circuit protection and shut down. If I only use one voice coil on the sub at 4 ohms it works fine. I want to put some component speakers in the front doors but the one I have are two ohms. Will these speakers cause the amp to shut down or will they work fine? Any suggestions are appreciated.
Like any number of people on here, using the front two channels of a 4 channel to run their comps or door speakers, the rear channels on the amp bridged to the sub.
It's not like it's a hard thing to do...
Kef
You can turn down the gain and not run as much power to your 6x9's. That amp is pretty small, so with the sub being ran off of two channels chances are that you're pushing the amp too hard and clipping it.
Kef
I understand that. My post was vague, but my reasoning is that two channels from a 4 channel amp is often times not adequate power for most of the subs made today like a L5 or whatever he's running.
The amp has 425 watts at 4ohms bridged. It should be enough power to run one L7 sub. But appearently this amp does not like 2ohms when bridged. I'm replacing the 6x9s with components. But will they run at 2ohms?
When you run bridged, each amp channel sees half of of the load. It sounds like you are driving a 2ohm load bridged, which means each channel would be seeing a 1ohm load, which is certainly not stable on that amp. Hook up one channel to each voice coil instead of bridging, and you should be cool (maybe just low on power, I dunno).
gl-john
gl-john
Spring Valley MN
capnxtreme
