kicker amp..
What size are they? I would even go larger if they only 10'' subs. Granted, the 1000.1 would work but it's not going to give full power. If it were me I would go with a 1500 or 2500.
That amp is 2 ohm stable. With 3 dual 2 ohm subs the highest ohm load you could get is like 1.3, I wouldnt run that amp at that low of a load. Look for an amp that does around 1500 rms @ 1 ohm and you will be fine.
But 3 12'' cvrs would be fine off a 1500rms amp or better. With those 3 subs you are seeing an odd ohm load, meaning a little bit less power is going to be sent, meaning you'll need a little bit bigger, more under-rated amp.
That amp is 2 ohm stable. With 3 dual 2 ohm subs the highest ohm load you could get is like 1.3' date=' I wouldnt run that amp at that low of a load. Look for an amp that does around 1500 rms @ 1 ohm and you will be fine.[/quote']
yes...maybe a Kicker SX1250.1 would be perfect ...for the trio...since that amp is 1 ohm stable...
jgoon
jgoon
fl
jgoon
