kicker 1500.1
great amp, rated at 2 ohms but can be run down to 0.7 ohms with a good electrical system. Expect around 2300 at 1 ohm and at 0.5 it actaully puts out more power than the zx2500.1 does at 2 ohms. Also strappable with a piece from memphis.hth
great amp, rated at 2 ohms but can be run down to 0.7 ohms with a good electrical system. Expect around 2300 at 1 ohm and at 0.7 it actaully puts out more power than the zx2500.1 does at 2 ohms. Strappable with a piece from memphis.hth
really well if i was to go bigger in the future say 2 15 L7's this amp can push them
yes. i have two 15 Mags off one zx1500.1 at 2 ohms. Strapped at 0.7 they put out around 6000 watts. If you run just one at 0.5 the zx1500.1 pus out around 3000 watts. At 1 ohms expect between 2300-2400 watts.They are not recommended to be run under 1 ohm daily. Even at 1 ohm they draw a lot from what i've been told so you'll need a good electrical system. I personally don't like to run amps under whats recommended by manufacturer because if something were to happen i don't want to be bassless waiting to get my amp fixed. But many have run them at 1 ohm daily successfully.hth
Please explain to me how the zx 1500.1 puts out more power than the zx 2500.1 @ 2 ohms. Last time I check the zx 2500.1 is reated at 2500w @ 2 ohms.
senbonzakera
ban him
senbonzakera
beale afb,ca
t-money
vegang
vegang
