kicker 1200.1...... 1 or 2
would it be that much of a difference in current draw since the power is the same..?? Also if this helps i have a 205 amp alternator and two yellow tops(1 under hood, 1 in trunk)
i guess i'm confused here.....would it not be the same power since i would be wiring each amp to see a 2 ohm load....w/ 1 amp it would be a 1 ohm load???from what i can tell there will be no extra power just a whole lotta headroom
//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
It'll be a little more power than one amp, while running more effeciant... I'd put both amps in there, unless you feel the $ you can make by selling the other amp is worth the small loss of power.
problem is, you have two DVC 4's, so a final 1 or 4 ohm load, if you strap the two KX12001's, load changes to 2 ohm, so you need two DVC 2's...or if you wire one to each sub, you still only see a 2 ohm load.
I say just use one...Your not going to hear a difference between the two because your going to be sending them about the same amount of power either way. Or buy a couple more 12's //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Nick-
I only have 1 1200.1 hooked up to both of my Dual 4 L7's and they slam extremley hard, w/ the proper box build that is...
thanks for stating the entirely obvious....i wasn't really planning on roasting two brand new woofers with double their RMS.....thanks for trying but the question was would it benefit me to run both amps since they will run much more efficiently at 2 ohms than at 1 ohm....just wondering if it would be worth it
00montecarlo
Livin'Loud
00montecarlo
Clarksville, TN
carchrism5
