kicker 12'' solobaric sub
stetson_p99
just need help making a sub box and what type of enclosure like ported or sealed and also size ?
* Nominal Impedance [Zn], 4 ohms [per coil] ; * Resonance Frequency [fs], Hz 26.4; * Power Handling Watts, Peak (RMS) 1500 (750); * Total Q-Factor [Qts] 0.36; * Equivalent Volume [Vas], ft3 (L) 2.3 (65.4); * Outer Frame Diameter, in (cm) 12 9/16 (31.8); * Hole Cut-Out Diameter, in (cm) 11 1/8 (28.3); * Mounting Depth, in (cm) 6 5/8 (16.8);
just go to "re" s web sit and use their ported enclosure program. You can play with it until you get the size and port length you want to accomadate the amount of room you have. I'd probably go about 3.75 cubes "gross" volume with 40 sq inches of port 24 inches long that would tune you to 35 hz. should be good. ...reaudio.com
if it's an older round style kicker solobaric DON'T, i repeat, DON'T use it in any enclosure other than sealed. and being a 12", it should only be used in a sealed enclosure that's smaller than 1 cubic foot. I had a few of these subs in my days and the only thing they're designed for are small sealed enclosures, and they pound in them. i'd recommend .75 ft^3 - .88ft^3.
its the cvx the round version of the sqaure one.......
its black with a silver symbol in the middle of it
it not no older than two year to three years old and is like brand new
stetson_p99
stetson_p99
OREGON
stetson_p99
