these are dual voice coil 2 ohm 10 inchers . I have 2 of these for sale. one is new coming from kicker in the next week and one is a slightly used(maybe 3 hours). I have pics of the used one and you all know what the new ones look like. They retail for 400. my screw up your gain. 235 for both shipped or 140 each shipped.
heres the specs
The Kicker Solo-Baric L7 woofers continue to be the best sub in their class. The patented square-woofer technology allows for 18% more cone, which translates to more bang for your buck compared to competing round subwoofers. All new for the 08/09 series is a redesigned and improved SoloKon one-piece, injection-molded cone with full-coverage back bracing that pushes more air and creates louder bass than ever before. The new beautiful look was inspired by the big brother SoloX series, and it's making everyone at Sonic go crazy as it's tougher looking and better-performing.
In addition to the SoloKon improvements, the new L7 woofers also provide a much easier installation. The solid pole piece allows more heat sink capabilities and perimeter venting is built into the spider landing unlike previous years. This also allows for a shallower installation as you no longer have to account for venting through the back of the magnet. To make things even easier on the installer, Kicker moved the binding post to the corners of the woofer allowing for an easier connection when running the subs in parallel or series.
Key Features:
* 10" Dual 2 Ohms Solo-Baric L7 Series Subwoofer
* Power Handling:
o Peak: 1200 watts
o RMS: 600 watts
* Impedance: Dual 2 ohms
* Titanium deposit impregnated cone woofer with rolled outer edge
* Santoprene rubber surround
* Full coverage back bracing
* Poly-cotton semi-progressive spider
* Spiralead™ tinsel-lead technology
* Highly-efficient UniPlate™ pole-piece/back plate
* Heat-reducing T-cut top plate
* Solid pole piece
* Cast-aluminum basket
* Spring loaded terminals
* High-temp dual 2 ohms voice coil
* Frequency response: 24-100 Hz
* Sensitivity: 87 dB
heres the specs
Key Features:
* Power Handling:
o Peak: 1200 watts
o RMS: 600 watts
* Solid pole piece
