Sold FS jl 450/4 325 shipped!!
KyleBechtold
Quit reading this
jl 450/4.. will have pics in a little bit
* Channels 1 and 2:
o Rated Power (stereo mode): 150W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
o Rated Power (bridged mode): 300W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
* Channels 3 and 4:
o Rated Power (stereo mode): 75W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
o Rated Power (bridged mode): 150W RMS x 1 @ 3 ohm-8 ohm (11V-14.5V)
* Peak Power Output 900 watts approx.
* Differential-Balanced Input Topology: (2 pairs of inputs)
* Channels 1 and 2 Crossover:
o Fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Channels 3 and 4 Crossover:
* THD at Rated Power:
* S/N Ratio*: >108.5 dB below rated power
* Frequency Response: 5 Hz-30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
* Preamp Output: 2-channel (Pass-through with selectable input sourcing)
* Bass EQ: +6 dB (variable boost up to +15 dB with Remote Bass Option)
* Infrasonic Filter (Channels 1&2 only): defeatable 24dB/octave at 30 Hz
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
* Fuse Rating: 60A
* Dimensions: 13.4"L x 9.25"W x 2.36"H
asking 325 shipped OBO
For anyone not understanding the specs of this beast..
You have 4 total options you can do with this..
4 channel 150x2 at the front 75x2 rear
3 channel 150x2 at the front 150x1 rear or 300x1 front 75x2 rear(you can switch how you have it so if you have a 300 watt sub and some comps you can run it that way)
2 channel 300x1 and 150x1
all can be hpf or lpf
I can't believe it.. I just bought an alpine pdx 4 channel... I shoulda waited a fawking day //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif GL w/ sale tho great price man
You still have this amp. Im wanting one bad but I need to push my Rockford t400.4 first. So its in excellent shape then? And your the first owner? PM me if your looking for anything in particular for trade.
KyleBechtold
Quit reading this
KyleBechtold
Tampa, Florida
Walled_Taurus
