Kia Niro w/Harmon Kardon - Stock speaker replacement
Go to crutchfield.com and enter your car model. Common beginner mistake is to replace midrange drivers with coaxials. Check it out, come back and will help you validate what you picked.
Yeah I've been reviewing Crutchfield options all morning. Seems like the fronts can accomodate a 6.5 in the door + 1/2" to 3/4" tweeters on the dash, and the rears would take 6.5" coaxial since there is no separate enclosure for a tweeter. Just to make sure I understand, you're saying go with components in front and then coaxial would be fine for the rear doors?
OK, here is the list I've got for the fronts. Basically I went with known brands with a max of 90-watts RMS. Not sure how to determine what the max RMS is per channel right now but based on my research it sounds like lower is better for the existing head unit/amp.
ModelPriceTypeRMS
JL c1-650
150​
component50
Rockford Fosgate r165-S
75​
component2-40
Infiniti reference REF-6530cx
197​
component90
Focal ISU165
330​
component70
JL c1-650se
229​
component50
Thoughts?
I'd look for something with high sensibility (dB) before rms ratings since you're on factory power. You also don't need to buy a complete component set with crossovers. Just make sure to match the impedance of your stock speakers.
OK I checked sensitivity and these are all 91-93 which seems to be the higher end and I'd assume fairly comparable. Any favorites from the list?
FamiliarRaspberry805
CarAudio.com Newbie
California
mahc
