Kenwood X889
95F150
Memphis MClass
All I can say is this deck is far superior than any I have ever had, which has been all Pioneers by the way. I heard that the only set back was them not being as user friendly as other head units, as I found out when I visited Best Buy to play with the similar version.
All I can say is for $280 I highly doubt there is a better deck out there! The sound coming from my speakers compared to my past 2 Pioneer decks, just blows me away!
All the downloadable Wallpapers and Screensavers on Keenwood, the G-Analyzer, and just the overall layout is great.
There are a couple set backs:
It is difficult to navigate, but a couple weeks and I or whoever owns one will have it down to a science. And almost everything can be done right through the remote, even the angle of the faceplate!!!
It doesn't have just the normal Treble, Midbass, and Bass options as the Pioneers I have owned, but I may be missing something, as I just put it in this morning, and keep learning new stuff every time I get in my truck. The manual says just keep pressing the Volume button for those settings, but doing that I only get Balance and Fade.
A great head unit, and that was a big step for me, considering I thought I would never buy anything other than Pioneer for a head unit!
Good Choice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW, the x889 has a 4 band PEQ instead of the traditional bass, mid treble. This allows you to adjust the exact frequency desired, and you can also control the decay (width of frequency adjustment).
Be sure to setup the Time Alignment, it does some amazing things for the better.
Haha, its sooo confusing compared to pioneers! I like to have my treble almost all the way up, what fequency would that be?
How do I set up time alignment? Is that where you tell it what size the speakers are?
"The manual says just keep pressing the Volume button for those settings, but doing that I only get Balance and Fade."
I have the KDC x979 and it took me a while to figure out all the settings too. try holding down that volume button for at least 2 seconds then try the other buttons too like the FM or AM buttons i found a lot more stuff doing that
The manual has instructions for x789 and x889, so there are different paragraphs of info for each deck. The info about pressing volume knob is for the x789 only. The X889 has the PEQ under the main setup menu (the 2nd little button from the left side), look for "EQ"
The Time alignment is really easy to setup, say you've just got comps in the front doors and a sub or two in a box in the back or your car. You roughly estimate the distance from the front comps to your ears, mine is set to 2.3 ft. Then you do the same for the distance from the sub to your ears, mine is set to 5.33 ft. Then once you are close, you can manually adjust the distances for best results. When sub is correct, it will be the loudest and tightest sounding, when comps are correct, the staging will improve, and midbass should sound better. Since there is no left/ right time alignment, you use the soundfield control setup that lets you choose the "focus" of the sound. choices are front, front-left, front-right, all, etc. Mine is set to front, as I've found setting it to front-left dimishes the width of the soundstage.
Also the SRS/WOW on the x889 really works well in correcting minor staging and imaging issues //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hope that helps.
Hope that helps.
It might not have helped him, but helped me out tremendously. I just purchased one and is suppose to be here in a few days. I tried and researched all the possible HU choices for under $650 and found most people to be very pleased with the x889. Can't wait....
Hope that helps.
Thanks, I will be sure and play with it today on my lunch break!!!
Ok guys, got another question!
All of my Pioneer decks used to show the title of songs on burnt cd's.
Why doesn't the Kenwood, is there something I can turn on to make it do this? Thanks/
It does, but not by default, you have to change display settings so song title shows.
I have mine setup to show song/album/artist on top, and RTA on bottom.
95F150
Memphis MClass
95F150
Thomasville, GA
Ricky616
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
