Kenwood KDC X592
  • 6
Joseph7195
Walkin Tall
Kenwood KDC X592 Headunit
I am selling this headunit, but it is so hard to give up, lol. It is in great working order 10/10 mechanical and 9/10 cosmetic, just because of normal use. it has a ton of features which will be listed below. Comes with remote and factory harness, which has only had the power-ground-remote wires used. I used the Preouts and had all my speakers amplified. Also has a detachable face. Has rear aux input and rear USB input with Ipod control. It has the ability to run 2 seperate sources at the same time. has a 24 bit DAc and built in crossovers. lots of great features.
General features:
CD player with built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)
plays CDs, CD-Rs, and CD-RW discs, including discs loaded with MP3, WMA, and AAC files (will not play rights-protected music files on disc)
detachable face with a 3-line fluorescent display
dual-zone capability lets front and rear-seat passengers listen to different sources
remote control
Audio features:
24-bit digital-to-analog converter
System Q EX Sound Control (6 EQ curves and a 3-band parametric equalizer)
"Supreme" audio processing for better sound from your compressed music files
speaker settings that let you tailor the sound to the size and type of speakers in your car
System E's+ high- and low-pass filters
Expandability:
compatible with Kenwood's Bluetooth adapter and satellite radio and HD Radio™ tuner
iPod direct control via USB input — no adapter necessary, but adding Kenwood's optional connecting cable lets you leave your iPod cable at home
inputs: rear USB and auxiliary inputs
outputs: 6-channel, 4-volt preamp outputs (front, rear, sub)
compatible with most factory steering wheel audio controls (adapter required)
NOTE NOTE NOTE: I will have to ship it next week at the earliest. When removing, I chipped a trim piece and the new one will arrive shortly, but I have to wait for it nonetheless.
$125.00 Shipped
Shipping and insurance will be included and it will be double boxed for the ride.
I would call Kenwood Tech support. Im sure they will try to help you
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
650
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
893
Joseph7195
Walkin Tall
Joseph7195
Saltillo, Mississippi, United States
Joseph7195
