kenwood deck problems
ford-204
4
wpg
.Originally Posted by Dukk
Best to refer to colors. Aside from the speaker connections, the deck will have RED, YELLOW, BLACK, and BLUE wires. Sometimes there is both a blue and a blue with a white stripe.
YELLOW - constant power. It keeps your clock and radio presets.
RED - Ignition power. Connecting this to power controlled by the key will have the radio come on when the car starts and off when the key is turned off.
BLACK - ground to bare metal.
BLUE - this is the wire that goes to the amp remote-on terminal.
If the deck has both BLUE and BLUE/STRIPE the BLUE goes to the power antenna ONLY, and the BLUE/STRIPE goes to the amp.
--------ok im new to this and my local electronics store trying to charge $160 to install it so i thought i would rather do it. my deck has a all those colors and it has a remote wire that is blue with a green stripe.there is also a power connection wire that is blue with the white stripe.Do i just hook it up color for color and my remote wire attached to the extended one from my amp. But in my deck how does a 12 volt get sent threw? do i need to attach a switched constant wire to the remote making it a three wire crimp??
........the wire from the deck which is blue with white stripe is your remote turn on wire used when adding an amplifier, that is the ONLY wire involved from the deck harness that needs to go to your amplifier. DO NOT ADD ANY OTHER WIRES TO THIS if you had a 12 volt constant wire added to this your amp will stay on without the car's key being turned on and your car's battery will have harm done to it.
--------so i just tape up the remote wire from the deck and leave it alone then?
-----------and also theres a blue with white stripe wire coming from my car audio harness ,what do i do with that wire
ford-204
ford-204
wpg
DBBOOM
michigan born
    May 14, 2026
michigan born
    May 14, 2026
