Kenwood amp wont turn on???
  • 2
93 saturn sl2
Michigan
I hooked up my Kenwood KAC-9102d to a friends system to see how his Type-R sounded. Everything worked fine for a few minutes. We had the system up for a few seconds and the amp cut off, but the triangle light was still on. I thought it went into protect, so we turned the radio off and back on, nothing still. Soon after that the light would come on and eventually die.
So what could be the problem? I didnt see any smoke, and all of the fuses are fine.
do you have a volt meter to see what your voltages are going to you power and remote? also make sure the ground is good. if that is ok then sounds like something wrong with power supply
We didnt have a volt meter at the time, but we hooked his amp back up and it worked. So that makes me think its the power supply. How much are those usually to replace?
if it is the power supply on the amp. it depends on the bad components. now did you say it works now?
It was working fine, then all of the sudden the sub quit working. We turned the radio on and off because I thought the amp went into protect, but that didnt work. After a few tries turning the radio on and off, the l.e.d. would come on and it would eventually die out.
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
461
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
93 saturn sl2
93 saturn sl2
Michigan
93 saturn sl2
    May 20, 2024
    May 20, 2024
