Keep frying my tinsel leads on subwoofer??
SourDeez
I recently purchased a lightly used 12" RE SE-x from a friend and it has been working fine for about a month until it stopped, so I took it out to find one of the negative tinsel leads had been fried off the little terminal. I soldered it back together and it worked fine until today (about 3-4 days) I fried off another one, this time a positive lead on the opposite side.
Any idea why this is happening? They aren't being overpowered.. So I don't know what would be causing this.
thanks
reason being is the re subs use short lead wire and ur pulling on it. you normally have to put a lil extra power over rated to do this or play below tuning.
in china they are cheap with the leadwire save 1/4" per lead thats 1" per sub times 1000. it adds up and they think of this in the tight production factorys.....
reason being is the re subs use short lead wire and ur pulling on it. you normally have to put a lil extra power over rated to do this or play below tuning.in china they are cheap with the leadwire save 1/4" per lead thats 1" per sub times 1000. it adds up and they think of this in the tight production factorys.....
Hmm interesting. How do you know they do that? the leads didnt seam THAT short. Also they were not just clean broken off, they were burnt up a little bit at the tip. Would pulling it off cause it to burn like that?
also one thing that seems odd is this never happened while the subs were actually in use. both times it happened I got out of my car (working) and when I got back in they were not working.
I was thinking its because of the cold temp's but I dont know.
clipped =/= underpowering.
clipping means the sine wave that's being sent to your subs has a flat bottom and top. what this means is that when your subs are playing and hit that flattened spot, they hold on to the same spot for longer than a normal sine wave. basically, this extra time the subs are playing at the peak's causes extra heat buildup in the subs. this extra heat most commonly burns up voice coils, but in your case it's burning up tinsel leads
your amp is what's sending the clipped signal. check your gains, bass boost on the amp should be set to 0. also, what amp do you have? a low quality amp could be sending a clipped signal
leads fry off because there is an area of high resistance... (forget all the clipping nonsense, ect)
In this case your easiest fix is to get all the old solder and lead out of the terminal with your iron and a solder sucker.. take a half inch or so of copper wire and weave some over the end of the lead, put the rest into the terminal and solder it all up... be sure to shrink wrap it...
What I like to do is cut the lead to 1-1&1/2" and install new full-length lead parallel to the end and double back and follow with heat shrink. Then, use good black rtv to attach that union to the cone and connect to the terminal. Never failed, just keep the mass down.... In my experience, reattachment has only ever been a temporary solution, and replacing and upgrading all the way to the coil wires is the best option if you are accustomed to, Nd willing to dig in that far. If the full length hasn't darkened fom heat, then it is merely from excessive flexing at the joint.....
SourDeez
SourDeez
Fuqy u
SPLaudio
