KAC-929 Kenwood 1000 watt amp.. are these any good?
  • Thread starter Unregistered
  • Start date
  • Replies 5
  • Views 8K
U
Unregistered
Guest
I want to power two twelve in mtx blue thunder subs. i hooked up a crossfire 35.2 and it didnt to ****. i used a rockford 800a4 and they pounded but
i sold that amp.
Are these 1000 watt kenwood amps any good? they say they are 2 ohm stable and can be bridged to 1000 watts
In my experience, I have seen the Kenwood amps be a great middle-of-the-road amp. They usually come with great extras for the price, but they sometimes feel a little shy on the power when you compare them to a Rockford or Kicker. If you are building a system that you will use at extreme levels during competiton, you should probably go with the big boys, but if you are building a system to enjoy for yourself, and the budget is a factor, the Kenwood is a good choice.
can this amp run a 2 ohm load when its bridged? and will it take a 5v signal from pre-outs?
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
553
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
801
Guest
53kicker
    May 31, 2024
    May 24, 2024
