Just received this amp... is it any good....suggestions...
icwe2
10
LA
Soundstorm Sta212 Stealth Mosfet Power Amplifiers (2-channel, 1200 Watts)
* TRI-MODE OPERATION
* BRIDGEABLE
* 2_ STEREO STABLE
* FREQ RESP: 9 HZ50 HZ (3 DB)
* VARIABLE LOW-PASS CROSSOVER: 40 HZ150 HZ
* FIXED HIGH-PASS CROSSOVER: 200 HZ
* VARIABLE BASS BOOST: 0 DB18 DB
* POWER & PROTECTION LED INDICATORS
* ILLUMINATED RED LOGO
* THERMAL, OVERLOAD & SPEAKER SHORT PROTECTION
* LINE & SPEAKER LEVEL INPUTS
* CHROME-PLATED RCA CONNECTORS & TERMINAL SCREWS
* REMOTE SUBWOOFER LEVEL CONTROL
* 600W X 2 MAX @ 2_
* 230W X 2 RMS @ 2_
* 1200W X 1 BRIDGED @ 4_
* DIM: 11L X 11.25W X 3H
not sure if its any good but I got it close to nothing //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif maybe thats why cuz it sucks Im not sure but I was wondering if its any good and how big of wiring ill have to get in my car to push this amp. Right now I have 800 watt rockford wiring would that be enough maybe if i added a capacitor. If I need new wirign I can get that any suggestions for good sub that would be good for this amp?
http://www.stootsi.com/store/item.aspx?item=21182180
I was hoping I wasnt going to here that response but something told me I would haha. Well I am looking at this amp... seem good any suggestions.....like I siad i have 800 watt rockford fosgate wiring.
Pioneer GM-D7400M
800 Watts Max. Power Class-D Mono Amplifier
* Class D amplifier minimizes power waste and heat generation.
* 800 Watts Peak Music Power
* Continuous Power @ 4 ohm: 250W x 1
* Continuous Power @ 2 ohm: 400W x 1
* CEA2006 Specifications:
o 400 Watts x 1, at 2 ohms
o 200 Watts x 1, at 2 ohms
o 80 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
* Extra-compact Class D amp circuitry for extra-versatile installation.
* Variable Bass Boost precisely controls audio balance and impact.
* 2 Channel RCA Inputs
* 2 Channel Speaker Level Input
* Hi-Volt (200mV ~ 6.5v) Input Level Control
* Built-in Crossover (40~240Hz, LPF)
* 2 ~ 8 Ohm Load Impedance Capability
* Total Harmonic Distortion 0.03%
* Signal-to-Noise Ratio 100dB
* Dimensions: 8-7/8" x 2-1/4" x 7-7/8"
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19066
it all depends on what your using it for. i have used soundstorm amps and subs with good results. i pulled out my hifonics 1206d to install a soundstorm 2500d and like it better than the hifonics.
ya what about that 800 watt pioneer amp i posted about up there I was just thinking of gettin that instead. Anyone know if this one would be good to get I was thinkin of gettin some jl audio 10s or some alpine e class 10s. tryin to keep the subs at a pretty decent price range
icwe2
icwe2
LA
moparfan1234
