Just got my PA A3000db in Pics*
A3000db data (Lab tested)
Actual power: (12.5 V, THD = 1%, 4 Ohm/2 Ohm) Wt 469/745
THD: (80 Hz, P = 0,1 Pmax, 4 Ohm/2 Ohm) % 0,085/0,058
Input sensitivity: V 0,21 — 8,7
Signal-to-noise ratio: db 82,5
Frequency range: (+0/-1db) Hz 17 — 140
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif Wow. Looks to be way overrated, even if PA uses 14.4 for their ratings....dont think going from 12.5 to 14.4 volts will make up for the difference of 745/1800......
Where was that tested at? If you have the paperwork, put it up in the birthsheet/benchtest thread.....Also, happen to have a 1 ohm rating?
Don't know where you got that waste of information from but you need to take a close look at what a digital volt meter is reading out on the speaker terminals. My A3000Db is putting out 64.9 volts A.C. at the terminals. That number is basically with the input sensitivity not turned up. I guess because the signal I am sending the amp is already so strong the amplifier does not have to work near as hard to put out the wattage.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif Wow. Looks to be way overrated, even if PA uses 14.4 for their ratings....dont think going from 12.5 to 14.4 volts will make up for the difference of 745/1800......Where was that tested at? If you have the paperwork, put it up in the birthsheet/benchtest thread.....Also, happen to have a 1 ohm rating?
These measurements have been lead by authoritative Russian magazine
"Avtozvuk" (CarSound in English) . The extensive test of amplifiers of other models of amplifiers has been lead. The test was spent in laboratory conditions. At measurement of capacity the stabilized power unit with a pressure 12.5 V has been used. For your interest I give the measured data for other amps. You will not believe, but MTX T81000d more powerfull than PA A3000db per 4 Ohm load //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
PA A3000db crossovers diagramm:
Rockford Fosgate P6001bd
Actual power(12.5 V, THD = 1%, 4 Ohm/2 Ohm), Wt 276/429
THD (80 Hz, P = 0,1 Pmax, 4 Ohm/2 Ohm), % 0.120/0.185
Input sensitivity, V 0.145 — 4.0
Signal-to-noise ratio, db 81
Frequency range (+0/-1db), Hz 13 — 170
RF crossovers diagramm
MTX T81000D
Actual power (12.0 V, THD = 1%, 4 Ohm), Wt 532
MTX crossovers diagramm:
to be continued
you'll need 0/1 awg power wire and ground. The amp does not need fuses, only the power wire does. I recommend a 200 AMP ANL fuse wired less than 11 inches from the battery post. You can get the fuse and fuse holder at http://www.knukonceptz.com
If anymore questions just shoot them at me, skeptikal, and Dave.
Um, actually the Fuse near the battery is just for that.... to protect the rest of the wire and/or the battery from damage.... the amp still needs a fuse/circuit breaker near the amp because that's what will protect the amp from damage.
ie, if the power wire near the amp is exposed somehow, possibly cut from the sheet metal of the car, then the wire will short out and possibly burn the insulation around the wire, this will cause the amp to blow unless you have a fuse to blow or circuit breaker to trip.... So, ALWAYS use something to protect the amp. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Anyway, any reviews on this amp? I am considering one for my XXX 15 as well....
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
james33440
