With everything else being constant, excursion doubles with a decrease of one octave. 20 Hz requires double the cone excursion than 40 Hz. If you're at/near the limit at 40 Hz and you play 20 Hz, your sub goes poof.Have to throw in some EE here, impedence of an inductor is j*2*pi*f*L, with j=i=imaginary, f being the frequency and L being the inductance, as you can see impedance increases with frequency //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I wasn't pointing the finger at you though. I could tell in your original post that you knew what you were doing. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYea I know all this, I was really going to be shocked if the sub didn't go when I was playing with it. Sundown 3kw @ .5 with a solid bass note at 26hz does some damage. The difference is I take all the blame. I don't really care though, the new re-cone will be able to handle it, which in the end it worked out better for me //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ah, somewhat of an odd phenomenon there. I know subwoofers are definitely not 100% analogous to inductors, but most of it is.With everything else being constant, excursion doubles with a decrease of one octave. 20 Hz requires double the cone excursion than 40 Hz. If you're at/near the limit at 40 Hz and you play 20 Hz, your sub goes poof.
PS: In subwoofers, inductance usually decreases above resonance before it begins to increase - especially in the target bandwidth.
that's why you don't even know I'm the one that bought the 80bux camera that you wanted //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gifhold the fckin show......
dragnix is asian //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
