The amp is on the way correct, but so everyone knows he sent me a pm saying one of the rca outputs didnt work so it was powerless on 1 side, but then came back and said it worked. So if it doesnt work on arrival there are going to be more problems. Although he insured the amp that does not mean he didnt send a screwed up amp in which im led to believe after this:
hey i have a lil bad news i just tired to c if the amp worked in 2 ch mode (ive had it briged) and it doesnt have output unless its briged. so would you still like me to send it or would you like the 400 and 10 bucks back or just your money back.
Well to answer that its only a 2 channel amp. So for you to have it bridged to run a sub or use it as a speaker amp (using the channels seperate) either or if the rca didnt work you would get little power! so that makes NO SENSE. If anything it would be 1 of the channels pos or neg terminal! Hints it only works in bridged mode so your only using 1 pos of 1 channel and 1 neg of 1 channel, which leaves another pos and neg unused!
1 more time dude STOP LYING //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
It works bro just told me that an rca was disconnected from the right side so thats why the right side had no output everything is in order i will ship it out now
