JL vs Kicker
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 512
  • 1
IMO, i like the sound kicker produces, over JL(except the W7), Car audio is all about your own tast, go out and listen to both the subs and see which you like more.
good luck
742
Guest
fu-man-chu
    May 24, 2024
