JL Sub Wiring Help Please
nathanz4c
4
UK
Newbie here asking for some help please.
Ive ran a single sub for a number of years now however my new car will allow me to run 2 small subs.
I have the following..
Rockford Fosgate P300-2 Amp with a power rating as follows-
4ohm Load Per Channel 75 Watts x 2
2ohm Load Per Channel 150 Watts x 2
4ohm Load Bridged 300 Watts x 1
This is currently running one JL 6W3v3-4 Subwoofer bridged with a rating as follows-
Continuous Power Handling (RMS) 150 Watts
Recommended RMS Amplifier Power 50 - 150 Watts
Nominal Impedance (Znom) - 4ohms
I wish to install another JL sub of the same spec. Im finding really conflicting information on how to wire these up for the best result.
Should each sub go to the left and right channels?
Or should they be wired in parallel cross the already bridged channels?
Thanks in advance for your assistance
You cannot wire them in parallel because that will create a 2-ohm load on the amp and it is not rated at 2-ohms bridged. Best way to connect for this amp and these subs is to put each sub on its own channel.
ONE ON EACH CH... DO NOT RUN BRIDGED... YOULL GET 150 PER SUB AS YOUR AMP IS STABLE 2 OHM OUT OF BRIDGE MODE...
YOUR AMP WILL RUN BETTER TOO BEING OUT OF BRIDGE MODE... HOPEFULLY YOU UNDERSTAND WHAT IM TRYING TO SAY IF NOT PM ME...
YOU SIR ARE CORRECT SINGLE VC.... THEY WILL BE PERFECT LIKE THE GUY SAID ABOVE.... JUST RUN ONE TO ONE CHANNEL AND ONE TO THE OTHER, DO NOT BRIDGE... YOULL GET 75W PER SUB WHICH IS THE RECOMMENDED FOR THAT JL SUB...
nathanz4c
nathanz4c
UK
nathanz4c
Mike Mccabe
