JL Audio XD 600/1 Amp for Sale
bigfrog05
JL Audio 600/1 Amp for sale-less than 100 hours of us
Highlights:
•mono subwoofer amplifer
•400 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
•variable low-pass filter (50-500 Hz, 12 or 24 dB/octave)
•switchable subsonic filter (30 Hz, 24 dB/oct)
•optional wired remote level controller
•Class D amplifier design with NextD™ switching amp technology
•differential-balanced inputs eliminate noise coming from your vehicle's electrical system
•Advanced Rollback Protection System prevents thermal shut-down
Connection Features
•preamp inputs and outputs
•speaker-level inputs (speaker wire to RCA adapter required for speaker-level input)
•high-level inputs — up to 8 volts RMS (about 16 watts)
•DC offset or signal sensing auto turn-on eliminates need for remote lead
•4-gauge power and ground leads and a 50-amp fuse recommended — wiring and hardware not included with amplifier
•no onboard fuses — when installing multiple amps in a system, an additional 50-amp in-line fuse between the distribution block and the amplifier is recommended
•8-9/16"W x 2"H x 7-1/8"D
$300 OBO
Will ship if shipping is paid
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). JL Audio XD600/1v2 Mono subwoofer amplifier — 600 watts RMS x 1 at 2 ohms at Crutchfield.com
Contact Brian 754-234-4537
bigfrog05
bigfrog05
sunrise, Fl
bigfrog05
