Audiomobile Elite 2212 12" Sub for sale
bigfrog05
Audiomobile Elite 2212 12" Sub for sale-less than 100 hours of us
Features
The Audiomobile Elite 2212 is designed to work in either sealed or vented applications, with smaller than usual enclosure requirements. Power handling is rated at 600 watts continuous, so you know the woofer is not only built to sound good, but also to be very reliable. Retail price in the U.S. is $399.95, and the woofer comes with a one year warranty. Audiomobile Elite 2212 12" Subwoofer
Built around a familiar looking rugged cast aluminum alloy basket assembly, the Elite 2212 is a fairly shallow woofer compared to others in this price and power handling range, with a mounting depth requirement of only 5.8 inches. This is a very deliberate feature, because the woofer also uses a special machined aluminum plate between the top plate of the motor and the basket. This feature is called I-CAR, which stands for Intercooled Conduction Aluminum Radiator. The real advantage is that it allows the motor assembly to be a solid unit rather than the typical vented designs used by almost every other manufacturer in the category. With no vented back plate coming out the back of the motor, the design allows the woofer motor to be in very close proximity to the enclosures back wall, which further reduces the required mounting depth.
The 70 ounce motor is comprised of a pair of high quality stacked ceramic ferrite magnets, and provides the magnetic energy to drive the 2 inch diameter voice coil. To provide the long throw excursion the voice coil is 1.3 inches in length. In the interests of sound quality it’s important to keep the moving mass as light as possible, so the multi-layer coil is wound using premium quality copper clad aluminum on a lightweight and vented Kapton former.
To keep the voice coil centered in the magnetic gap, an 8 inch composite Nomex and cotton linear-type spider is riveted to a special mounting ring that is fastened to the basket.
The cone of the Elite 2212 has also received some attention to make it as light and stiff as possible. The actual cone that attaches to the former is made of a material Audiomobile refers to as CLS, or Composite Laminated Sandwich. No less than six layers of synthetic fiber, Kevlar, and natural fibers are pressed into a rigid parabolic shape, and then a one piece dustcap is glued on top to increase overall strength and stiffness. The outer diameter of the cone is attached to the basket via a nitrile butadiene rubber (NBR) surround. The woofer comes with an integrated frame gasket that can also accommodate an optional grille to protect the speakers moving parts from damage.
$200 OBO
Will Ship if shipping is paid
(List pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-Trader system or less than 10 references that you have sold to in the past. (These must be listed in your signature, or a link provided to a feedback thread listing these references)). PASMAG | PERFORMANCE AUTO AND SOUND - Audiomobile Elite 2212 12" Subwoofer
Contact Brian 754-234-4537
bigfrog05
bigfrog05
sunrise, Fl
trumpet
