im getting some new speakers but i do not know which ones i should get here are the specs
p312d4=
Subwoofer Size: 12"
Impedance: 4 ohms
Dual Voice Coil: Yes
Peak Power Handling: 2,000 watts Per Pair / 1,000 watts Each Sub
RMS Power Handling: 1,000 watts Per Pair / 500 watts Each Sub
Surround Material: Foam
Sealed Box Volume: 0.65 - 0.85 cu. ft.
Ported Box Volume: 1.25 - 2 cu. ft.
Sensitivity: 87dB
Frequency Response: 20 - 200Hz
Top Mount Depth: 6-3/8"
Cutout Diameter: 11-1/8"
Warranty: 1-year SE
jl audio=
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 300 Watts
Voice Coil: 2.25" diameter, 4-layer, Kapton former
Available Configurations: Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
Sealed Enclosure Range: 1.00-1.50 cu.ft. (28.3-42.0 liters)
Ported Enclosure Range: 2.00-3.00 cu.ft. (57.0-85.0 liters)
VRCâ„¢ Technology: YES
Elevated Frame Technology: YES
p312d4=
Subwoofer Size: 12"
Impedance: 4 ohms
Sensitivity: 87dB
Warranty: 1-year SE
jl audio=
