Sold JL Audio E6450M 6 channel amplifier
SilverSPL
Works perfectly
Has one scratch mark in bottom right corner besides that it looks new.
Was barely used, has about 3 hours of use on it.
$150 shipped UPS Ground, double boxed.
Class AB with patented absolute Symmetry dual N Channel MOSFET output design
Power Supply - Unregulated MOSFET switching type
Rated Power (Stereo) - 45W RMS x 6 @ 4ohms (12.5V)
Rated Power (Stereo) - 75W RMS x6 @ 2 ohms (12.5V)
Rated Power (Bridged) - 90W RMS X3 @ 8 ohms (12.5V)
Rated Power (Bridged) - 150W RMS x3 @ 4 ohms (12.5V)
THD at Rated Power:
Signal to noise ratio: >104dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10Hz - 25 kHz ( +0, - 1dB)
Damping Factor: >200 @ 4ohms per ch./50Hz / >100 @ 2ohms per ch. / 50 Hz
Slew rate: +/- 22V/us
Amplifier filter type- State-variable, 12dB/octave Butterworth with continuous variable cutoff frequency selection from 50-200 Hz. Configurable as Low Pass or High Pass Defeatable.
Dimensions (LxWxH): 17.7" X 9.25" X 2.36"
Thanks,
Matt
SilverSPL
SilverSPL
Telford, PA
SilverSPL
