JL Audio e4300 4 channel amp
Spooney
Amp is not in the greatest physical shape.It has its share of scratches but works flawlessly. I'd give it 6/10 physically and 10/10 functionally. In the pics you may or may not see that the amp is missing 4 speaker terminal screws. These screws will be replaced before the amp is shipped to the buyer although they most likely will not be chrome plated like the ones that come stock in the amp. At any rate you will not be missing any screws if you purchase this amplifier. Here are the specs for the amp(copied and pasted from sonicelectronix.com):
Class AB 4-Channel Amplifier
Absolute Symmetry Class AB Circuit
Differential, Noise Cancelling Input Topology: RCA jack inputs(low-level) and multi-pin jack(high-level)
On-board crossover: State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50-200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output: Pass-through type
CEA-2006 Compliant
RMS Power Rating (14.4V):
4 ohms: 70 watts x 4 chan.
2 ohms: 110 watts x 4 chan.
Bridged (4 ohms): 220 watts x 2 chan.
Bridged (8 ohms): 140 watts x 2 chan.
RMS Power Rating (12.5V):
4 ohms: 45 watts x 4 chan.
2 ohms: 75 watts x 4 chan.
Bridged (4 ohms): 150 watts x 2 chan.
Bridged (8 ohms): 90 watts x 2 chan.
Frequency Response: 10 - 25kHz
Damping Factor: >200 @ 4 Ohms / 50Hz, >100 at 2 Ohms/50Hz
S/N Ratio: >104 dB referred to rated power(A-weighted, 20Hz-20kHz noise bandwidth)
Input Range: 200mV - 8V RMS
Bass EQ: +6dB Fixed Frequency, Fixed 'Q' with port for optional remote bass control
Slew Rate: +- 22V/us
Dimensions: 13.8" L x 9.25" W x 2.36" H
Fuse Rating:40 amps
90 Shipped in the lower 48 states only.Will also listen to trade offers but would prefer to sell
Shipping included in price. I usually ship USPS but I may also use UPS or Fed Ex if it makes it faster to get the amplifier shipped out to you. I can also use any one of those three at your request.
Spooney
Spooney
Charlotte,MI,USA
Spooney
AJ (ACE)
    Jun 28, 2026
