Sold JL Audio e1400D Sub amp
rlcowboy
Ok for sale is a JL Audio E1400D Mono Block amp. This amp does'nt have a scratch on it as u can see in the pics & is in the box with manual. I bought this amp from an authorized JL dealer & only used it a few weeks. The ONLY reason I am listing the amp is because I ended up putting in two W6's & I am pushing them with two 500/1. The amp will push a 12w6-D4 just as good as a 500/1, found that out a little too late. If you're into clean sound quality & CLEAN power for your subs, then this is the amp for you! This amp, as with all the JL Audio mono amps, is VERY under rated! It will give u OVER 500w RMS @ 2 Ohm at 12.5v. Im gonna go ahead & price this thing to go! $180 +shipping, Pm me with any questions, thanks.
High-damping class D circuit with discrete control circuitry (U.S. Patent #6, 441, 685);
Differential-balanced input topology: RCA jack inputs (low-level) and multi-pin jack (high-level);
On-board crossover: fully-variable (40-200 Hz), selectable slope Low-Pass (12 or 24 dB / octave);
Preamp output: pass-through type;
Bass EQ: +6db fixed frequency, fixed 'Q' (defeatable) with port for optional remote bass control (RBC-1);
Dual mono speaker output connections accept up to 8 AWG wire;
+12V and Ground connections accept up to 4 AWG wire.
rlcowboy
rlcowboy
Evans,Ga
rlcowboy
