JL Audio Dilema
loudmusiq
Ok I'm going to be using 2 JL Audio 12w3-D4 subwoofers that run at 250w maxes as well as RMS maxes. My idea for my amp was wiring a JL Audio 500/1 amp to run the two subs. Now I know it can be done, but will I be able to still get enough power to bump. If you're responding let me know on a scale of 1(no power) - 10 (top performance). If it'll **** could you do me a favor and look on BUYLOUD.com and see if you can find me a mono or 2 channel amp strong enough to power them well for around $430. I NEED YOUR HELP, PLEASE HOOK ME UP
Perfect set-up just like you have it. Wire the subs voice coils in paralel so that each sub is 2 ohms, at that point you can wire the subs together in either paralel (1ohm mono) or series (4 ohm mono)- either way, you should have impressive output with the proper enclosure.
Take it easy,
-zane
2 12w3's are great on a 500/1, 250 rms, but jl lies in a good way, i have put 1 500/1's on 1 12W3 and it was f'n gorgeous!
Oh ang go with 4 ohms, the jl amps won't give you more power at 1 ohm because of the R.I.P.S. technology , so just make it easier on the amp run it at 4ohms, mine is at 4 and it friggen rocks!
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
180
loudmusiq
loudmusiq
Washington
AllJL
    May 31, 2024
    May 24, 2024
