OldOneEye
The Rockford 3Sixty.2 does it (as does the 3Sixty.1).
Main difference between the two is the equalization and xover. Both will take a decks volume dependant EQ and get flat it (so both use a 30 band EQ to unequalize the signal coming out of the factory deck (which uses equalization so they can protect speakers, use smaller speakers, etc.) Once they are unequalized and flat, the .2 has a 30 band EQ for all the outputs (the .1 has like 5 bands) as well as the ablity to do highpass, bandpass and low pass on the output channels. (the .1 has like a low pass I think for the sub output). So if you have amplifiers with built in Xovers and you want to use those, you can use those and can probably get away with a .1 instead of the .2.
The .2 is basically an Rockford EPX2 controlled by a Palm minus a few features. I am in the process of reviewing one right now for work and if you already have a Palm (or are considering the Palm or shortly something running the Windows handheld software), it is probably a bit more powerful than the cleansweep. It will also sum signals which the JL one requires outboard boxes.
If you are interested you can PM me and I can give you a price that is a little more aggressive than what is out there right now (I work for one of only 2 guys that are authorized to work online).
More info here:
http://www.rockfordfosgate.com/products/product_compare.asp?cat_id=1&locale=en_US&comp=(106185,106187)
Juan
More info here:
Juan
Is there anything out there that does what the cleansweep does and has the equalization feature?
