JL Audio 8w7
rjay
Question on the wiring. So it's a single 3ohm sub, but the amp I will be getting will be max output at a 2ohm load. I know some of the JL amps are full power from 1 to 4 ohms. But how does it if your amp is say 300watts @ 4ohms and 450watts @ 2ohms, obviously want the most power from the amp. Thanks
Don't do it. To low of a load on amp can cause it to get hot and blow
what?
it will do a power in between the 2, no ohm load is constant anyway so you never see rated power to begin with. You will be fine running a 3ohm driver on a 2ohm stable amplifier.
rjay
rjay
oklahoma city
rjay
