MisplacedTexan
I have found a JL 500/1 (not the V2) for sale locally at a good price so I decided to do some research:
Its claimed output is 500w RMS, and the manual says that a 50A fuse is required. Assuming that power measurement is at 14.4V, then its efficiency would be 500/(14.4*50)=69%. Right?
Then I found the following review of the amp, quoted below: http://www.carsound.com/review_archive/amps/jl_5001.html
“At 1/3 of its maximum output, the 500/1 measured 57 percent efficient, which is somewhat lower than the rest of the class D units that we’ve seen to date. In addition, the efficiency remains in the mid 50’s all the way to full output rather than increasing to the 80-percent-plus that we’ve seen in other units. The result is an amp with efficiency that’s about 30 percent better than a class A/B unit at 1/3 output and roughly equal at full output.”
The same review claims output of 600W RMS from the amp. If the amp is in the “mid 50’s” efficiency, there’s no way it’s making 600W or even 500W of power (It’s 425W if you assume 59%). Am I missing something here, or is someone lying/ measuring incorrectly?
