JL Audio 300X4 Jl Audio 500x1 ( 80 amp alternator)
Hero4u
Hello everyone. I just bought a new Truck a 2013 Toyota Tacoma. I previously had these 2- JL amps in my GMC Sierra- which I think had a 150 amp stock alternator in it. I never had any electrical problems and have all this stereo stuff in a closet and wanting to upgrade the factory stereo system. I would like to keep the factory head unit as I did in my GMC and I already have a JL clean sweep to clean up the signal. My question is with these 2 amps ,will I have to upgrade my alternator. Battery. and start adding electrical upgrades ? I truly would like to leave the electrical as is ( factory) but I am concerned about these amps pulling too much power from this 80 amp stock alternator. Back in the day I got into using multiple amps and ended up having to do this but it was like having to charge the batteries ect.. I just want to use these 2 amps . The JL 500x-1 to run 4- 8inch kicker subs and the JL 300x4 to run the mids and tweets. Does anyone know if my 80 amp stock alternator with be enough? Thanks everyone from S.FL
Thanks you guys when you say 1/0 you mean one amp?
No, they mean run 1/0 wire from batt to a distro block, then you can run your 4 gauge wires from the block to the amps. Should suffice for your situation.
So that means 1 big wire (like 0 gauge) to distro, then 2 smaller wires to amps (4 gauge)
I don't know the most about car stereo but I am familiar with electrical, others can give more advice but this is what the guys are telling you.
Hero4u
Hero4u
Delray Beach FL
Staynlean
