Sold Jl Audio 300/4
slam
Jl Audio 300/4
This amp works like it should. It is used and has some minor scratches(see pics).
$200 plus pp and shipping
Specifications:
* Rated Power (stereo): 75W RMS x 4 @ 1.5 ohm-4 ohm (11V-14.5V)
* Rated Power (bridged): 150W RMS x 2 @ 3 ohm-8 ohm (11V-14.5V)
* THD at Rated Power:
* S/N Ratio*: >108.5 dB below rated power
* Frequency Response: 5 Hz-30 KHz (+0, -1dB)
* Damping Factor: >200 @ 4 ohm per ch./50 Hz
* Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions: 13.4"L x 9.25"W x 2.36"H
Features:
* Differential-Balanced Input Topology: (2 pairs of inputs)
* Front Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Rear Crossover: fully-variable (50 Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave)
* Speaker output connections: accept up to 8ga. wire
* +12V and Ground connections: accept up to 4ga. Wire
slam
slam
fort worth, tx
slam
