JL Audio 10w6v2 wiring help needed
lastcall
lastcall
got 2 of them coming in and want to make sure i wire it correctly. i noticed on these subs that that only have one set of -.+ terminals. these are both dual 4 ohm subs so they will be down at 1 ohm correct? i have a viper 1200.1 right now and need some assistance on how to make it work. im prob missing something easy here.....file:///C:/Documents%20and%20Settings/EMitschke/Local%20Settings/Temporary%20Internet%20Files/Content.IE5/096JWTEZ/MVC_076S%5B1%5D.JPG
this says it is.......
Model Rated Power @ 4 ohm Rated Power @ 2 ohm Rated Power @ 1 ohm Crossover Bass EQ RCA Output Protection
d300.1 200 x 1 300 x 1 N/A var. 12dB low-pass Yes 8 dB Yes, stereo T,S,D,R
d600.1 275 x 1 400 x 1 600 x 1 var. 18dB low-pass Yes 8 dB Yes, mono T,S,D,R,O,L
d1200.1 450 x 1 800 x 1 1200 x 1 var. 18dB low-pass Yes 8 dB Yes, mono T,S,D,R,O,L
d2500.1 1500 x 1 2500 x 1 N/A var. 18dB low-pass Yes 8 dB Yes, mono T,S,D,R,O,L
i could run it at 4 ohms wth the memphis amp and still get 600w each
Oops, you were right. The 1200 IS stable at 1 ohm... the 2500 is stable at 2 ohms. Just go to the jl website and follow the wiring instructions. Your subs should have jumpers...
lastcall
lastcall
lastcall
League City, Tx
lastcall
