Jl 500/1 or 1000/1?
The 1000/1
The 500/1 is only 250 @ 4 ohms, 500 @ 2 ohms
The 1000/1 is 600 @ 4 ohms, 1000 @ 2 ohms
Your only running 1 4 ohm sub so the 500/1 would not even run RMS into the sub
Plus you would have the room to add a second if you ever wanted to
14.4 is the voltage your car should be putting out while running.
The 1000/1
How do you suggest running the 1000/1?
should I just keep the gain halfway?
Are you installing yourself or going through a shop?
I’m going through a shop. They told me JL is the way to go. I had JL back in the day and I loved it my budget was 1500. So I got a 4 channel jl amp off eBay to power the highs which are the cp1’s and I’m getting that JL wo 12 box. I’m just trying to figure out is the JD500 enough or should I get the 1000
There are so many
JL is great don't get me wrong but they want your first born.
For the kind of money your going to spend on the JL's you could get... (plus have a money to have a box built. Don't get a prefab box)
https://store.soundsolutionsaudio.com/icon-12-1250w-subwoofer-by-ssa/
https://soundqubed.com/product/s1-1250-monoblock-amplifier/
Or these guys are having a sale right now so if you hurry
https://audiolegion.com/collections/armada-series/products/armada-12-inch-car-subwoofer
https://audiolegion.com/products/al1600-1d-1600-1d-monoblock-car-amplifier
That's just a couple examples
Sundown Audio, Taramps, American Bass, are a couple other brands to look into
If you have already paid I have stated that the 500 will only put out 250 @ 4 ohms which is underpowering the sub
The 1000 will power it
If your having it done by a shop then have them set your gains unless you own a multi meter
If so then here is how to do it
if you get the 1000/1 (id get it), dont just turn the gain half way up. set the gain right. heres how. the test tones are at the very bottom of this link...
Carlos1son
CarAudio.com Regular
Carlos1son
old bridge NJ
nauc
