jl 1000/1 wiring help
gene evans
21
PA
Ok the drivers i have is 2 12w6's and I want to wire them up to my jl 1000/1v2. only problem is i don't know how to wire the subs for the ohms. if i wire each 12w6 in parallel for 2 ohm would it stay 2 ohm with this amp, or having both would drop it down to 1? I just want the max output, right now their wired to 8 ohm a piece parallel. thanks for the help.
peep the 2nd diagram, since the 1000/1 isnt stable at 1 ohm, and no reason to risk it even if the rise of the box will put it at a 1.5ohm load. I've seen the low ohm light go on in my buddies car with the same set up when he had them wired to 1 ohm. Just wire it to 4 ohms and ure good.
gene evans
gene evans
PA
gene evans
